SLK001
Stainless
- Feb 8, 2015
- Coral Springs, FL USA
I need to fabricated a spindle sleeve for a D1-4 spindle. Problem is, is that I don't have access to a D1-4 spindled machine. However, I have been able to gleen the following information from the internet. If you have a D1-4, can you verify this info?
The first drawing if of the important dimensions that I believe a D1-4 has:
This next drawing is a D1-4 with a spindle sleeve inserted. I have information that a D1-4 faceplate is 1.5" through the middle. With the "nose" of the spindle extending 7/16" beyond the flat of the spindle, this means that to be flush with the outside of the faceplate, the sleeve needs to extend beyond the mouth of the spindle by 1-1/16". This the the dimension that is in question. Can someone confirm these?
