etard
Cast Iron
- Jul 30, 2010
- redlands, CA
Damaged 10K / Scratch that... 9"
Ok, I can't resist a 10K, they don't pop up on CL that often and I find them aesthetically pleasing. I may have overpayed, but with SB prices where they are, you can't really lose. I wanted a taper attachment and steady rest, now I have both... and 2 10K's. The lathe has fallen on it's nose and has a few broken bits, which if you have them on hand, let me know through PM or email [email protected]
From the pics you can see the chip tray is bent, the switch on the front is damaged the crossfeed and compound took a hit. The gearbox is a little loose on the headstock, and I couldn't get the compound to move until I backed off one of the gib screws. I did notice 2 differences between this and my other 10K; the headstock cover seems to be aluminum and the crossfeed dial is smaller like a 9" on this damaged lathe. Does that age the lathe? Also, it is on the cabinet without the 3 storage drawers.
Here is a list of what I need:
1. left hand gearbox lever
2. compound screw and handle
3. rear taper attachment mount and rod
4. crossfeed handle
Here are the pics, they speak for themselves, sorry if they load up slow on your dial up connection:
4. crossfeed handle
