leod
- May 24, 2014
- oregon city, or
I have seen and looked into a dc motor conversion for a Bridgeport, but what about for a 13" top drive. I was thinking make a single flat pulley and run it straight to the largest step on the lathe from as small of one on the motor as possible without too much friction loss and use a speed controller on a 2 hp motor or so. Would I have enough power at the lower rpm without the idler shaft. It's not like I would be using a puny little treadmill motor like people put on 9" lathes. I already have a 1/2 hp and controller, but I doubt it would handle a heavy cut without the idler reduction. It would sure cut down on a lot of bulk. Anyone done this? benefits? drawbacks?
