I have a small-spindle heavy 9 (1936 vintage 409-YN).
Will need to get a drawbar collet closer at some point.
Measured the length of the spindle - appears to be about 12-11/16" long.
Based on some rough calculations using the dimensions of a 3C and the dimensions of my 3AT collet adapter for my other lathe (which can't be mentioned here, but think Ayn Rand shrugged), I'm estimating that the threads on the collet will be somewhere between 10-3/8 and 10-7/8 from the left end of the spindle.
I've seen closers that were 10-1/2" from the end of the collar to the end of the tube, but that seems a little too short (would only be 1/8" engagement).
Maybe my measurements or calculations are off. It's been a long day of shoveling and blowing snow.
Anyone know what the correct dimension should be?
Also, can I just take the cone-shaped sleeve off and shorten it to get the length on one that's too short to the correct length?
Steve
Steve
