panabax
- Mar 28, 2015
- Dallas, Texas USA
So I have been looking for a collet setup for my 9A. I have considered the 3C setups, but have decided against them due to cost and the limitation on the already small stock that can pass through. I also considered a 6K setup with a 10K spindle upgrade but that becomes stupid expensive.
I considered a 5C chuck, but cost is still higher than I wanted to spend and the 5C chuck really reaches out farther than I would prefer for a collet adapter. It would, however, be fast and allow the full spindle bore to be used.
I then found a number of threads on using the ER32 and ER40 collets. Since I would want to maximize precision, I decided against the several one piece 1 1/2-8 to ER32 chucks I found. I would either need to make one myself on my lathe or get a plane back chuck. Although these chucks are pretty reasonable, they were still more money than I wanted to spend.
Well, I found one at hhip.com. I had never been to their site before. It seems like many of the other US sites selling Chinese machine tools. However I got to their sight because Google led me to a $62 plain back ER32 collet chuck. They also had a matching backplate with 1 1/2-8 threads and the three through holes pre-drilled for another $26. So I was able to get into a new ER32 setup for my 9A for less than $90. Collets are cheap and plentiful on fleabay. I paid $54 for a 19 piece metric set which runs from 2mm to 20mm. That should more than cover any size stock (metric or imperial) up to the spindle capacity.
I will have to machine the backplate to determine how accurate this thing really is, but it "looks" really nice. I will report back when I get my High School 9A up and running and get the backplate machined.
Part numbers are 3901-5032 and 3900-3112. I got the three inch (80 mm) chuck because I figured the smaller the better (they also advertise a 4" - 100mm chuck). I will take a lot of material off the backplate as well to snug the whole assembly up as close to the spindle as possible. This setup should allow me to pass 3/4" stock all the way through the spindle. It also allows me the versatility of running an MT2-ER32 chuck in the tailstock and an R8-ER32 chuck in my mill/drill for one set of collets for nearly every occasion.
If anyone is looking for an alternative to the original 3C setup, I don't know how you could beat this without making the chuck yourself (which is, of course, a perfectly good alternative).
Baxter
Baxter
