Faceplate
Results 1 to 7 of 7
Thread: Faceplate
    Dec 2017
    Indiana
    65
    16
    7
    Default Faceplate
    I figured I would run this by the forum before re-purposing this piece.
    I have a lathe faceplate which is approximately 15 3/16" in diameter and 2 3/8" thick with 2 3/8-6 threads.
    I was under the impression that it would fit a South Bend 16 or 16-24. This has been thrown into doubt by a forum member who believes it will not clear the feet on the headstock casting (thanks for the heads-up Tom).
    Thing is, the large faceplate SB offered for the 16-24 is 22 3/4" dia., so why doesn't it rub?
    Does anyone have a 16-24 with the large faceplate, who can offer some insight?
    Does anyone know of another lathe which has a 2 3/8-6 spindle which this would fit?
    I'm just trying to figure out what I have, and if anyone can use it, before I turn it into a base for a grinder pedestal.
    Aug 2004
    ventura,ca.usa
    255
    20
    Hi JA, don't have a good answer for your question but it seems like the plate would make a better drill press table than grinder base... Jim
  3. Likes rj1939 liked this post
    Sep 2010
    moscow,ohio
    4,497
    450
    1343
    It depends on how much the hub projects(side view)
  5. Likes SBLatheman liked this post
  6. #4
    Jan 2008
    southern il
    489
    66
    166
    For a grinder base, I like something similar to a 1 ton rear brake drum.
  7. #5
    Sep 2014
    Arizona
    641
    458
    187
    Here are some pics illustrating the limitation on my 16" machine. The faceplate shown is 13-1/4" in diameter, but because it sits so tight to the headstock, there's room for only maybe another 1/4" max radius/1/2" diameter to miss the Sphinx feet.
    Hope this helps. Feel free to cross-post the photos over on the For Sale page for your buyers.
    faceplate-clearance-01.jpg faceplate-clearance-02.jpg faceplate-clearance-03.jpg
  8. Likes ja762 liked this post
  9. #6
    Jul 2004
    Houston, TX USA
    27,198
    Who knows if it would fit, but the 1910 16" Lodge & Shipley was 2 3/8-6 with a rather long 2 7/16 pilot bore behind
  10. #7
    Jul 2009
    Munster, In. USA
    1,942
    338
    492
    I am looking for a lathe faceplate to use on a Silver drill as the original was hacked by people probably long ago dead.
    John
