I've been slowly disassembling the lathe and on the taper attachment (gonna call it a clamp) that rides on the way you snug down, was broken right at the point or top of where it rides on the way. Is that part only for the 14 1/2" or would one off a 13" or 16" fit? Anyone one have an extra for sale?
Another thing I noticed is that the ways are approx .018 lower at the head stock then at the tail stock. How I came about this is I ran the carriage full right, snugged up the adj bolt then slid table full left and used a feeler ga between the adj stop and the bottom of the carriage. I do plan on checking again after the table is off, using the flat area between the ways as my reference point. Unless there is another place to check from.
There are no wear grooves on the ways just some good deep scratches so I'm hoping nothing was patched and my naivety on lathes I missed it.
The lathe is missing the steady rest so I will need to try and hunt one down too, Hopefully that is not a hens tooth.
With the lathe being the small bore 1.325 am I understanding the old sb catalogs correctly that its a 4c Colet with no adapter. Basically can I just use a 4c Colet find a draw bar and nose protector and go I won't need the adapter.
