New to the forum and learning as quickly as I can. Bought this 14-1/2" SB and almost up and running.
What I think I know is that the quick change gearbox talks about threading feeds which is something that I'll want to be able to do.
The gearbox has a few settings with a 48 tooth stud gear and then like 95% of the threads are with a 24 tooth stud gear.
I think I've identified where the stud gear is. In the second photo, the gear that I'm pointing to with the screwdriver has 38 teeth. The gear to the left of that one, on the same shaft, has 48 teeth.
So I think I need to obtain a 24 tooth gear and replace that 38 tooth?
Would that be the correct position for the 24 tooth gear?
Any help in identifying and sourcing the 24 tooth gear?
Thanks in advance for any assistance.
