Hello,
I am planning on adding a gear box to convert my 9c to a. In doing some research, it seems I will need to purchase 20 and 40 tooth stud gears (1 each) and a 56 tooth gear box gear. I can also use my existing 80 tooth idler gear. What other gears will I need for the conversion? In looking at some photos, it seems as if there are more gears than just these.
Also, my lathe did not come with reverse tumbler gears. How often do you find yourself using these?
