An alpine resort close buy where to send this old lathe to the scrapyard. I came to look at it. And it looked really bad. Very dirty. And a belt, so I was thinking antique. A lot of equipment followed so I figured it had some value. When I got it home I searched it up. And it seemed quite attractive. And now that I have it working, I am very pleased. Cleaning these old machines is a terrible job. But it feels good when finished.
I'm making this thread though because I have various questions that I will come back to.
I also have a colchester student mk1,5. So not sure I would need this lathe. But it's heavier and somewhat different. And bigger, so maybe it can do things the student can not do. Not sure. Horsepower seems similar. We will see. Just tried a few cuts so far. Some problems with the belt. The ones I tried first, made lots of noise and slipped, and ran oof the pulleys. I finally tried to more accurately grind the belt down where I glued it together, so it's more like one belt. Seems to work much better. I think I should have a wider belt though.
There is an odd thing though. Both the cross feed screw and the compound screw seems to be metric withe pitch 3mm and 4mm. So I didn't take the chance to order new nuts on ebay. Didn't seem to be similar. There is also a sign on the back to do metric threads. The lead screw however is imperial, with I think 6 tpi pitch. The cross slide doesnt have axial bearings, So I think I should try to add that if I can find something that can fit.
Toolpost seems a Tripan 311. Just one toolholder so that is a shame. I'll post pictures of the accessories once I've cleaned them. A lot of gears.
I guess my main question is, is the lathe good? Is all the work worth it? Thanks
