Is Grease the answer?
MDM12
Jun 16, 2013
OHIO
I've been putting the C oil in my cone pulley on my 44' 10L. Problem is, it slowly weeps oil out the fill hole while running making my middle cone slick and my belt always wants to slip off. I'm wondering if the grease stevewb sells would cure this problem? How is it working out for you guys that are using it?
It works for some, others have issues with the cone heating up.
Regardless it seems you have sealing issue that needs to be addressed- grease may slow it down but probably won't cure it.
Grease is not the answer!
GREASE IS THE WORD !!! :)
I solve my problems and I see the light
We gotta loving thing, we gotta feed it right
There ain't no danger, we can go too far
We start believing now that we can be who we are
Grease is the word
They think our love is just a growing pain
Why don't they understand it's just a crying shame?
Their lips are lying, only real is real
We start to find right now, we got to be what we feel
Grease is the word
Grease is the word, is the word that you heard
It's got groove, it's got meaning
Grease is the time, is the place, is the motion
Grease is the way we are feeling
We take the pressure and we throw away
Conventionality belongs to yesterday
There
is a chance that we can make it so far
Grease is the word
Now, Grease is the way we are feeling
This is the life of illusion
Wrapped up in trouble, laced with confusion
What are we doing here?
We take pressure and we throw away
There is a chance, we can make it so far
Grease is the word
Grease is the word
Is the word
Is the word
Is the word
Read more: Grease - Grease Lyrics | MetroLyrics
SORRY COULD NOT RESIST :nutter:
The screw in the cone pulley is supposed to have cone point for sealing. I would guess the original screw was lost and a standard set screw was used.
Tom
There is also that spring ball detent system they used later on, if there is gunk around the ball bearing it might not be sealing.
This is typical...obviously its not sealed.
Not so obvious to me, there's a taper on that plug. If it goes against the corresponding seat, it could be used to seal It. there must be a purpose to that taper or else it would not be their. That's an extra operation and expense.
I meant that obviously, the plug is not sealing off the cone. See the first pic of the oil leak.
