Green Chinese Drum Switch
Results 1 to 5 of 5
    Jun 2008
    Western, PA
    87
    5
    Default Green Chinese Drum Switch
    I just wanted to give everyone a heads up about those green drum switches you see on Ebay. The price was very attractive for an equipment project of mine. I was going to use it on a 1-1/2 HP 110 volt motor so I bought one at the rated volts and amps. While the guts of the switch may have been rated at that voltage, the box in which it was mounted had virtually no room for the wiring. It is shipped with two flimsy rubber grommets in 1/2" holes that do not allow the use of any kind of normal electrical connections let alone conduit. So unless you are wiring a 1/100 HP motor with phone wire don't bother, spend the money on a real one
    May 2012
    Central New York
    222
    9
    35
    Chinese products never fail to disappoint.
    Dec 2009
    Nashville, TN
    35
    6
    It's not the disappointment - it's that you only feel satisfied for half an hour.
    Or the uncomfortable guilty feeling after the all-you-can-consume buffet.
    Oct 2009
    Colorado
    1,068
    6
    85
    Quote Originally Posted by iron_junkie View Post
    At least they're reliable
    May 2009
    New Jersey
    201
    21
    13
    Quote Originally Posted by paulsomlo View Post
    More like consistent
