hardtail69
- Mar 22, 2015
I am slitting brand new DOM steel size 1.5 id. x 2.5 od. In other words half inch wall. the slitting saw was doing just fine and i completed one, but on the very next one the next day (so It was not over heated) it went in about half and inch and then started making a hellacious noise. i had been using plenty of cutting oil same as yesterday but when i took the piece out to examine it I noticed that just one side of the 4" x .125 saw every tooth was damaged, but only on one side. Now I had drilled several holes in this DOM and when it got to the first hole is when the damage occurred. The slitting saw was just HSS do you think that drilling the holes work hardened the hole wall and the slitting saw could not handle it? is DOM prone to work hardening? Would using a cobalt slitting saw work or would I need to go to carbide? Oh and I am doing this on my 1947 model 9a south bend lathe.below is the piece i am making. thanks for your advice in advance.
the clamp not the round thing
