Frank Fox
- Feb 13, 2009
- Wilton, Ca. USA
I replaced the front oiler on my SB-13, head stock noticed some thing funny. The pipe plug that is just above the oiler cup, Aint there on either oiler. Only an un taped hole? Just a vent? was painted shut, so drilled it out, think most of the paint came out in/on the drill. I used my pump(plues) oil can and pumped oil in the newly cleaned out hole, and oil overflowed out of the (Gits) oil cup There is NO drain plug below the filler cup (cant drain reservor) I also noticed there is no (GITS) oil cup for oiling the tail stock? There is no (GITS) oiler on the belt tentioner, handle bearing, like the tail stock, just a hole to put a drop of oil in as also on the lead screw hi-lo lever by the "single tumbler" QC box. This is an ex-NAVY 1942 lathe.
Should I think about drilling a drain hole and tap it for a pipe plug, same for vent hole's, tail stock for a GITS oiler? dont do any thing?
Frank
Frank
