Flying Dutchman
Cast Iron
- Jan 20, 2005
- Heemskerk, Holland
Headstock Disassembly
Is there any special 'trick' in removing the Spindle?? I've loosened all the Cap Screws, Expander Screws and Take-up nut expecting the spindle to slide out. Wasn't planning on taking the Headstock apart at first for repainting, but figured that I would like to change the Oil Wicks and flush the Bearing Oil System based on the amount of crud and debris found elswhere in the lathe (QC Gearbox, Apron etc.).
Your help will be highly appreciated.
Best regards,
Piet Butter
Best regards,
Piet Butter
