Hi guys,
I am a new member and wonna be garage machinist. I say wanna be cause I haven't used a lathe yet. That being said, I have already purchased a SB 9C and tore it down completely to powder coat the parts and rebuild whatever necessary to bring the lathe to top shape before using it. However, I have a concern.
The headstock bearing area and spindle shaft have some scratches and I was wondering what would be the best way to address this issue. I've read somewhere in the forum that the SB9 is limited to 1400 RPM. If I've not mistaken, this is due to the metal to metal and the lubrication system. I wanted to upgrade to a DC brushless motor in the future as well and I thought the best way to get rid of the scratches and at the same time be able to take advantage of the higher RPM DC motor upgrade in the future would be to machine the headstock/spindle/both to press in couple of high speed/high temp capable bearings. What do you think of this solution? Are there any negatives about doing this?
I was also thinking to find a good used headstock and call it a day. Or even buy a used headstock from a newer year model with the copper bushing that I can buy and press into the headstock. Of course I welcome any other suggestions you may have. Here are some photos for your review. Thanks in advance for all the help.
