Hi,
I purchased a used heavy 10 that I am starting to go over. It appears to be in very good shape but does have a few issues. The first that I am tackling is that it came with three 5C Nose cones, all of which have the small pin sheared off. Looking with a magnifying glass, I can not tell what style head these pins have. It is possible that they tried to remove them and stripped whatever head was there. It looks like there are threads so I do not believe it is just a pressed in pin. Is that correct? Does anyone know the specs for this pin and what style head it is supposed to have? I really do not want to bugger it up more by just trying whatever I can find to get it out. Worst case, I can drill it out and if the threads get damaged, I can tap a larger size and grind the end of the screw to be like the original.
If it is just a press fit pin, then i can press it out and replace.
I did search on the web for quite a while and I could not find anything.
Thanks for your help.
