Greetings!
Recently, been having clutch release issues, which almost caused a crash. For reference, the lathe is a late 50's 10L.
The photo shows the condition of the clutch lever and the “extra” shimming, as purchased. In addition to the (I think original) thrust washer, there are a couple of brass shims and a plain washer that was fashioned into a thicker shim (a section was sawed-out to make a “U” shaped shim that was slipped under the cam). So, obviously, something is not right.
This set-up had been working ok, but recently the clutch stopped releasing normally and the feed continued after a normal lowering of the lever. The feed was stopped, but after forcing, or jiggling, the lever in the extreme down position. It's hit and miss now - sometimes no issue and sometimes like described.
Before I tear into the apron for a full rebuild, has anyone seen external shimming like this before and might know what the internal issue could be?
Thanks!
Bob
