Well I have finally gotten my, new to me SB Heavy 10, into position and leveled up and power to it. The bearings seem to run smooth and quite. When I engage the feed lever to engage the lead screw I get a lot of whine when I run the motor in the forward direction. When I run the motor in the reverse direction, it is a lot quitter. I do not see any missing teeth on the gears and they do not look worn to the point of being pointed yet. Tomorrow or sometime this week I will try and remove them and clean them up good for better inspection. In the meantime anyone have any ideas or things I should be looking at?
On another note the cross feed screw and nut have about .052 back lash, would just replacing the nut improve this any, or should the screw and nut be changed as a unit.
By the way this is my first SB lathe and only my second overall. I am replacing a new Jet 14X40 with this, so I am trying to learn what to do. This forum is a great help. I will also get and add some pictures this week if I can up load them.
Thank You
Keith
Thank You
Keith
