Heavy 10 Headstock bearings - Split?
Results 1 to 19 of 19
    Jul 2017
    Michigan
    83
    8
    8
    Default Heavy 10 Headstock bearings - Split?
    I am continuing to tear down my heavy 10 for restoration. I'm starting out with the headstock, and after opening it up, I realized the expander/wedge part is missing from the bigger bearing. I got to looking for a replacement online, and I noticed all the headstock bearings for the heavy 10 seem to be a solid design with a split at the top.
    (ebay example: NICE ORIG SOUTH BEND HEAVY 1 LATHE SMALL/LARGE BEARING CAPS & SLEEVE BEARINGS | eBay)
    Few questions:
    1. does anyone happen to have just the expander for large bearing for sale?
    2. is this an uncommon bearing design? I cant find any other info or images online, everything else is the 1 piece bearing design.
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    that's jacked up...
    Really can't imagine why someone would do that, I guess I was their attempt to make new bearings....did they work ok?
    Might want to pony up the 100 bucks...if you do use your original caps though.
    Feb 2007
    Auckland, New Zealand
    124
    7
    6
    Why on earth would someone sell the bearing caps separate from the original headstock they were bored with?
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    They don't know any better...it is rather silly.
    Jul 2017
    Michigan
    83
    8
    8
    So the ebay link I posted has the caps and bearings, and they appear to be in pretty good shape. I really dont want to shell out the cost of an entire headstock to get matched bearings, you dont think there is some standardization to these bearings? There's also a bit of adjustability to them so I figure they would work, no?
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    Yes, you may swap in good used bearings without issue.
    Again, do not change your original bearing caps...if you buy the eBay deal only use the bearing shells and expanders....toss the eBay caps somewhere right off the bat so there is no chance of mixing them up.
    Jul 2010
    Virginia, USA
    3,148
    76
    503
    If I were you, I would buy that ebay deal, and tell the seller to keep the caps and put them back with the headstock casting.
    allan
    Jul 2017
    Michigan
    83
    8
    8
    Quote Originally Posted by iwananew10K View Post
    Ahh, ok, I follow now. I misunderstood to mean you need the bearings to be matched to the headstock it paired with, not the caps.
    I'm still a little confused about my current bearings because all the milling appears to be very clean, not something that was a diy replacement. I'm wondering if this might have just been a very early/late/short production run. I'm gonna clean them and test for runout before I jump at replacing them altogether.
    Thanks everyone for your input.
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    For sure not anything SB did.
    Just a reasonably skilled hobby guy or a job shop expedient to get the machine going.
    Bronze just machines nicely.
    Jul 2017
    Michigan
    83
    8
    8
    Just got it back together and whoever made them did a great job. They needed some tuning but the runout is now nil. Glad I didn't jump at replacing them right off the bat.
  11. #11
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    Runout is the easy part.
    Making a set of bearing and maintaining alignment is the harder part.
  12. #12
    Mar 2016
    New Jersey
    886
    16
    169
    Does the vertical play come out right? How about the side to side? Usually that isn't checked but with the style of bearing you have, I can see where it could be right vertically but not horizontally.
  13. #13
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    I would replace them.
    Lots of potential issues here...one being in the absence of a top oiler the THAT split design isn't going to work very well with a bottom fed capillary system...at least in my mind anyway.
    Add that there is no positive means of locking them in the bores,they are just kinda flopping around in there..seems like asking for trouble.
  14. #14
    Mar 2016
    New Jersey
    886
    16
    169
    I think its meant to use the expanders up top as the locking mechanism. bottom side, I guess maybe it keys on the capillary wick tube?
  15. #15
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    Yes, the expanders and oiler tube are effectively relegated to "flop limiters"
    in use it may be fine, but is not founded on good solid practices IMO.
  16. #16
    Oct 2017
    UNITED KINGDOM
    I had my heavy ten apart a few months back and don't remember the bearings being in two parts. Mine are one piece, located at the bottom on the oiler and split at the top for the wedge. The idea with the wedge is to expand the bearing and firmly lock it into the casting. Can't see how your bearing can work this way.
    If you find somebody to supply these bushes new I would be very grateful if you would let me know as these are like hens teeth here in the UK.
    Ken Wheeler
    P.S Just been out and removed the back bearing cap to confirm, and yes the bush is in one piece.
  17. #17
    Oct 2017
    UNITED KINGDOM
    Ken Wheeler
  18. #18
    Sep 2010
    moscow,ohio
    4,207
    422
    1196
    Beau, pretty much you are limited to whatever eBay has to offer or you may contact Ted at the link below...he probably has some NOS bearings, they will not be cheap, but Ted can absolutely be counted upon to do his part to deliver the goods.
    [email protected]
  19. #19
    Oct 2015
    Virginia
    260
    10
    44
    Dan,
    Have you purchased anything yet? I dug through 3 crates of H10 parts and found you a pair of bearings and expanders. The insides are cool but the grooves are slightly chewed up. Still usable and free if you want them.
    Please email me, I don't check here every day.
    [email protected]
    Click the linky thing for a pic.
    Imgur: The most awesome images on the Internet
  20. Likes iwananew10K liked this post
