Heavy 10 headstock thread
Results 1 to 11 of 11
    Jun 2017
    UNITED KINGDOM
    6
    Default Heavy 10 headstock thread
    can any body help me on head stock thread on a south bend 10 I just got I believe it has a
    1.1/2" x 8 tpi and need to no does the thread have whitworth type thread with 55 degree angle or American type thread with a 60 degree angle new lathe work and over in England and a lot of lathes over here use whitworth threads would appreciate any help
    Sep 2010
    moscow,ohio
    4,049
    403
    1141
    SB is 60 deg
  3. Likes internationalgeo liked this post
    Jul 2004
    Houston, TX USA
    26,785
    Made with either 1 7/8 - 8 or 2 1/4-8 if it was the large bore version. no whitworth, no 55 degrees
    Assumes you do mean Heavy 10
  5. Likes internationalgeo liked this post
  6. #4
    Jun 2012
    Michigan
    7,744
    2249
    2506
    Quote Originally Posted by johnoder View Post
    If you think it a 1 1/2-8 and johnoder says it a 1 7/8 or 2 1/4-8.. then you better had measure it with proper tools to be sure... that seems way apart..
  7. Likes thomasutley, internationalgeo liked this post
  8. #5
    Jun 2017
    UNITED KINGDOM
    6
    thanks Johnoder
    for the reply cannot get the chuck off at the moment (Seized)removed chuck from back plate and it only seems to be about 1.1/2"cant measure properly but the faceplate that came with it is 1.1/2" x 8 tpi but not sure its the right one the hole in the other end of the spindle is only 1" so I think its only a regular spindle not the larger spindle if that makes sense
  9. #6
    Jul 2004
    Houston, TX USA
    26,785
    Quote Originally Posted by internationalgeo View Post
    thanks Johnoder
    Its easy. If a "Heavy Ten" it has one of the threads mentioned in my post above. If it has a 1 1/2-8 thread it is not a "Heavy Ten" - but could be a "light Ten" or "10K"
    Serial number right end on top in between two front ways will tell us exactly what it is
    A 199 Z with a 108XXX serial is a 10R from early forties with 1 7/8-8 thread
  10. Likes itsmeBernie liked this post
  11. #7
    Aug 2013
    715
    412
    194
    One of the tasty sites to figure out what you have...
    http://www.lathes.co.uk/southbend/index.html
  12. Likes internationalgeo liked this post
  13. #8
    Jun 2017
    UNITED KINGDOM
    6
    hi again john
    serial #108262 cat199Z would that make it light ten or 10K would help if I could find out
    regards george
  14. #9
    Jun 2017
    UNITED KINGDOM
    6
    Thanks for your help I shall have another go at getting the chuck off and measure again
    tomorrow many thanks
  15. #10
    Jul 2004
    Houston, TX USA
    26,785
    See revised post #6 above
    hi again john
    regards george
  16. #11
    Aug 2013
    715
    412
    194
    See post #39 of this thread for how to hold the spindle when removing a stuck chuck.
    How to Remove a Stuck Chuck -- Tutorial
    John
