Papagrizzly
- Mar 19, 2007
- Bellingham, Wa
Heavy 10 owners, what would you change in your Heavy 10 to make it an Ultimate Heavy 10?
I assume we're not talking about things that could be a sensible modification, but rather features we'd want in a re-design...
A few come time mind:
- much higher spindle speed (I tend to machine small parts)
- get rid of the damn flat belt and make it so you don't have to splice/cut it (pulling the spindle is tolerable however).
- tailstock that grabs the tang on the morse taper so they won't twist in the tailstock (I find that one almost inexcusable).
- better lever closer design
Ken
Tailstock with a tang - good idea.
QUOTE]
Thats an easy fix. A .59 cent brass 1/8" pipe plug and an hour and your tanged bits will never turn again. Just drill and tap where your flat would be on a tanged #2 MT drill bit, screw in the brass plug and grind off whats left to make it smooth...Bob
Replace leather belt with serpentine belt - requires no modification to machine and
costs about ten bucks. A no-brainer.
Folks who wish for something to grab the tang on morse taper drills don't understand
how morse taper drills work. The tang is not there for driving. If the drill spins
because the taper in the ram is marked up, or the drill taper is defective, the
tang will shear off under heavy loads.
Notice
