pistonring
- Nov 25, 2005
- MD 21921
I have a Heavy 10 South Bend tool room lathe and want to set it up with a piston type Aloris copy tool post system. Which size range is the best fit? I have an Enco Q35 post that looks big. The center line of the piston locks are about a half inch above the centerline of the lathe when sitting on the compound rest. It would most likely best be used on one of my larger lathes later on. I am assuming that a 100 or AX series will fit but how about the 200 or BX series? Which size are you guys using and which would you rather have? I realize that in either case I will likely have to do some milling to get the lock into the tee slot. Opinions please?
Thank you,
Dave Reed
Elkton MD
Thank you,
Dave Reed
Elkton MD
