Heavy 10 Taper Attachment Scew
Results 1 to 4 of 4
    Jan 2015
    Missouri
    64
    10
    Default Heavy 10 Taper Attachment Scew
    Picked up a taper attachment right here on the forum for my Heavy 10 which came with everything except the taper attachment screw (the one with the splines). I'm considering making my own, but need the dimensions if anyone has one. If no one has the dimensions, but instead has one to sell, I'll consider that as well. They would need to be for large dials. Thanks.
    Nov 2015
    29
    I believe Brian Miller at Miller Machine and Fabrication can make those.
    He made me the cross slide screw for my taper attachment. Its excellent. I had him change the dimensions a bit to accommodate the new thrust bearing's that are thicker than the originals. It's important to set up the backlash in the taper attachment correctly as it is a significant cause of cross feed backlash.
  3. Likes Stronghold liked this post
    Jan 2015
    Missouri
    64
    10
    Quote Originally Posted by Dana22Rim View Post
    Thanks, I forgot all about that company. Could you give me more info on the thrust bearings?
    Nov 2015
    29
    The thrust bearings I used and the only one's I could find are Boston Gear 17195 Available at MSC P/N 03548591. They are thicker than the originals at .281 THK. I had Mr. Miller make my lead screw smooth part slightly longer than the original so the bearing race on the end would not fall off the 3/8 portion and would stay centered.
    South Bend Form 978A parts list is very helpful. I think you google it.
