I am new to this forum, and am in need of some advice. I actually got this lathe from a friend a little while ago. I haven't ran it much, but I am noticing that the larger bearing is heating up. First thing I did was check for excessive movement in the spindle, and it would only move about 1 1/2 thousands, which i believe is ok. Next thing I did was pull the caps off and remove the whole spindle assembly to get to the oilers. I replaced the capillary oilers and flushed the system. While I had it apart I was looking at the spindle and the larger bearing seemed to spin more rough than the smaller. I than decided to take apart the spindle and see if it had some crud between it. It doesn't seem to have any metal shavings or crud, just grease. However after cleaning the bearing and spindle, there is scoring on both. I'm not sure if this is something I need to replace or if I can clean it up somehow. Im guessing im going to need to replace them. Where do I find replacements for this? I attached some pictures so you can see what it looks like. Thanks for the help, it is greatly appreciated.
