franketrozzo
- Oct 5, 2004
- Brevard, NC
Anyone know how to adjust the drive gears on the heavy ten? I threw the tumble lever while the spindle was still turning, which caused a clickity clack noise around the tumbler gears. It only happens in one feed direction, feeding away from the spindle. I checked all the teeth for damage. The drive gears on the banjo bracket were not fully engaged so I nudged them a bit closer. Added some open gear lube. Still getting a clackity noise. Question is ... is there an adjustment on the tumbler gear engagement?
