Hoping for some insight.
Don't see how these "events" could be linked, but could be wrong...
A couple of days ago I removed the carriage handwheel (blocked underneath the apron housing, then tapped out the taper pin) because I had a bug up my azz to polish it as I'd never done it when I restored the lathe a couple of years ago.
Did that, slipped it back on and tapped the taper pin back in place.
Try to do some turning/threading today, and the clutch will not disengage from either the X or Y feed.
Like a dummy in a hurry (which I was), thought it may have been "stuck" and put a pair of pliers on the star wheel to get a better grip as it was oily. Turned counter clockwise with fairly light pressure but enough to promptly snap the left-hand thread screw.
So I found a replacement LH screw on Fleabay, no luck on a clutch shaft. This is used in my shop several days a week, gotta get it fixed FAST. I would love to NOT have to spend an entire day tearing the apron apart ( I need to move a safe that's located at the end of the lathe bed to be able to slid the apron off...).
Any suggestions for removing the LH screw that's snapped off inside the clutch shaft? E-Z outs are designed for RH thread, and no used clutch shafts on Fleabay. Thinking about putting the shaft vertically in the mill and trying to mill it out to the minor OD and (hopefully) pick out the threads after?
Any idea what's caused this and how to fix?
