fox32223
- Oct 13, 2012
- Jacksonville, Florida
Hi all, I bought a heavy 10 a few months back to do a full restoration. I think it’s a 1961 or 1962 based on a website with serial number registration. The serial # is 12449 RKL 16. The Catalog # is CLC 8187 Z. As I have been going through it I discovered that the chip tray is bent in the area under the quick change box. I thought no big deal I can straighten that, but upon closer inspection, I noticed that when you lower the lever to change gears it comes within a 1/8” from hitting the chip tray. Soooo now I understand why it was bent down. This where the mystery starts. What is causing this to have an inference between the levers and chip tray?
• Was the lathe moved to different cabinet?
• A replacement gear box was installed?
• Are there suppose to be some small risers between the chip tray and lathe that were lost?
I looked for documentation showing when SB changed the cabinet designs from year to year, but couldn’t find any. If anyone has this knowledge let us all know :-)
A lot of guessing has been going on in my mind, but now I’m looking for some definitive answers.
Has anyone seen this before?
Thanks in advance for your help!
Greg
Greg
