Brandenberger
Hot Rolled
- Sep 19, 2017
Hi,
Still working on my first south bend 10 heavy... disassembling the reversing gear. The twin gears came off the bracket nicely, but the reversing gear itself seems to be going nowhere despite following the directions in the ilion book, ie remove the nut and stud gear, then pressing out the shaft with a arbor press (3 ton).
The lathe is a 1940 era machine and has no felts or oil passages on the bracket for the twin gears, though it has a oiler git for the main reversing gear shaft. The key also doesn't look like a step key, but probably a single flat piece.
Any suggestions would be appreciated. The rotation of the gear is a bit rough so wanted to get it apart and clean it out and replace the felt I expect to find...
Picture: IMG 1253 — imgbb.com
Thanks!
Phil
Thanks!
Phil
