Hello All,
I recently purchased a 1929, i believe 9", at an auction and i am trying to put it together. From what i can tell it has raising blocks in the cross slide and the tailstock but nothing under the head. My problem is that the banjo has like a hook on the end of it that hits the gears before the rest will mesh up. Is this because i need the raising block in order for it to work with this banjo? Are these ever available if that is my problem? Can i remove the other blocks and change the banjo and be up and running until i come across/make a block? Any and all help is appreciated as i am not even sure what model i have at this point. Serial # is 44557 S if that helps to answer any of my questions.
Zach
Zach
