mbphoton
- May 22, 2009
- Florida USA
Hello Everyone,
For me the answer is...I don't know!
I have a 9A. 1941 or so. It's not perfectly adjusted, the gibbs should be a bit tighter, I'm not great at grinding bits, etc.....
I was cutting some 2 inch alum for a job and was getting a little bored so I thought I'd try to go faster. I doubled my depth, no problem. Just the same usual slight hiss sound over the noise the motor itself makes.
I doubled again, no problem, again....Finally I'm cutting 3/8 deep in a single pass with just the same slight hiss sound. Beyond that I don't know how deep I could cut. I ran out of the ground part of my cutter!
My feed was slower and I didn't do it too long as the curl coming off of the cut was just too much to control, it was a mess, but 3/8 deep and the machine barely noticed it was cutting anything.
Does anybody know how deep you can really go with a Southbend?
Mbphoton
Mbphoton
