How to disassemble the spring loaded knobs on the South Bend 9A?
Results 1 to 7 of 7
    Aug 2017
    Ohio
    34
    10
    Default How to disassemble the spring loaded knobs on the South Bend 9A?
    I don't know what they're technically called, but I am referring to the spring loaded plunger knobs that control the quick change gear box, as well as the drive selector knob on the apron that selects between half nut feed, power feed, and power crossfeed. The handle portion of mine are quite rusty and it would be nice to take them apart for cleaning and polishing, but I haven't found anything on how to do so. Is it generally ill-advised to do so, or is it straight up not possible? Thanks!
    Sep 2010
    moscow,ohio
    3,850
    392
    1066
    You can do it but unless there is a problem IMO it not worth it because it's a PITA.
    but if you must...look for posts from FTFengineering on the subject.
    Sep 2015
    Florida
    272
    38
    True that.
    Been a couple of years since my resto, but I remember looking into it at the time and said hell noooooo....just finding the taper pins was a job in itself IIRC.
    But, mine weren't that bad.
    Nov 2014
    41
    19
    My 9A (1945) was not too bad. Made a couple punches, one 3/8 T6 and the other
    3/8 brass. With these you can get the pin to move without damaging the knob then
    change over to the correct pin driver. Guessing with a steel driver is gonna leave
    an ugly spot. Just a note, my pins were NOT tapered.
    Backed the knob up with a piece of oak on top of a large piece of steel then
    kinda best guessed as to where the pin was. On most you can get a fairly good
    idea by cleaning very well and then using a strong magnifier. Some folks were
    able to look in the hole in the end to determine pin orientation. Good luck and
    stay safe.
    lsneon
    Aug 2017
    Ohio
    34
    10
    Ah, I didn't know there were cross pins. They do blend them in pretty well! I managed to find them, but yeah, it does look like a gigantic pain in the ass. I think i'll pass!
    Aug 2013
    682
    384
    186
    This comes up all the time. Unless the springs are rusted in there, I'd leave them alone...
    Another thread on the same topic:
    Removing spring loaded pin on reversing gear?
    Jan 2014
    South Jordan, Utah, USA
    318
    745
    100
    I couldn't bear to not disassemble mine. The pins were not that difficult to drive out. Mine were not tapered, so finding the small end is unnecessary. I replaced the pins with stainless set screws.
