Dufferdave
- Jan 28, 2006
- Massachusetts
I’m restoring an old South Bend 9" model C but I’m having trouble removing (disassembling) the toolpost slide. The entire compound slide area was caked with some kind of gummy, dried shellac which I’m slowly cleaning away – but it makes everything stiff and difficult to disassemble.
Anyway, I removed the gibs (on both dovetails) so the dovetails are loose, and the cross-slide came off nicely at the end of it’s travel – but not so the toolpost slide! I separated the toolpost slide from the cross slide by removing the set screws but I can’t get separate the toolpost slide and I don’t want to force anything. The toolpost slide goes to the end of it’s travel but then binds – but maybe it’s really gummed up?
OK guys, what’s the procedure here??
