Josh Bowman
- Aug 4, 2012
- Spring City, TN
I'm new at this machining, so please be gentle.
Tonight, I wanted to make an adapter to fit some of my wood coring blades. They have a tang that's a little over a 1/4" and 5/8" wide and 2" long. My first thought was to use my chinese mini mill, but found the bits to be too short as well as the head above the vise. So I turned to the SB 9A and its mill attachment. I tried to drill a hole 2" deep, no problem but which way to go after the first hole? The bit won't drill another close hole without bending and besides I'll have waste left in the hole. Any suggestions? I'm thinking of just boring a 5/8" hole and allowing the blade to lean in the hole, but was hoping for a more eloquent solution. Sorry for the bad cell phone pictures, but they'll give an idea of what I'm doing. These are the tang on the bowl coring blade:
Here's the lathe setup I have to work with:
And here's the best I have in mill bit length:
Any ideas or help would be appreciated.
