How To Mount A Drill Chuck In The Tailstock?
Results 1 to 9 of 9
    Sep 2008
    171
    Default How To Mount A Drill Chuck In The Tailstock?
    Yes, I know this will seem absolutely basic...but...my tailstock quill does not have the recess for a tang. It is Mt2 and that is it. So how in the world do I get a drill chuck that won't start rotating when I want to drill a hole in a piece of metal?
    This is for a 1928 9" Model O.
    Thank you.
    Mar 2012
    Hamilton, New Zealand
    372
    518
    249
    A correctly fitting Morse taper does not need a tang, the friction is normally enough to transmit the torque. Get a standard drill chuck with mt armour and saw off the tang with abrasive saw so it fits your quill.
  3. Likes Nitromahn, WJ Birmingham liked this post
    Sep 2008
    171
    Thank you sir!
    Jan 2010
    Indianapolis
    1,215
    713
    374
    Or get an MT2 for drawbar applications, and install a tang screw when needed.
    VERTEX 39-79 Tang Screw for Mt2 Draw Bar M1 x 1.5: Amazon.com: Industrial & Scientific
    Mar 2016
    New Jersey
    921
    16
    179
    Mine also had problems gripping. I borrowed an MT2 reamer to clean it up and the problem stopped. The quill has to be extended a bit so the tang oesn't hit the screw though.
    Jul 2004
    Houston, TX USA
    27,446
    The only lathe I have that DOES have the tang socket is one that someone modified
  8. Likes SteveBausch liked this post
  9. #7
    Jan 2010
    Indianapolis
    1,215
    713
    374
    Don't peck in brass.
  10. #8
    Dec 2005
    Langley, B.C.
    111
    7
    The quill has to be extended a bit so the tang doesn't hit the screw though. Is you quill fully retracted when you try and insert the drill chuck?
  11. #9
    Jul 2003
    savannah, jaw-ja
    1,537
    834
    311
    I used tanged MT arbors specifically so that the arbor "ejects" when the TS quill is fully withdrawn.
