Domodude17
- Aug 14, 2017
In todays segment on "Cheese Head Screws", i'm dealing with a stripped set screw that holds the cross feed nut in place. I've soaked it in WD-40 for 2 days, and put literally as much weight as I can on the screwdriver when trying to turn it, but it still cams out because the slot is so bad. Does anyone have suggestions here? I was thinking about replacing the cross feed and compound nuts just on principle while I have the saddle apart, but id like to try to avoid chiseling and cutting things apart if possible. Thank you.
