robert102653
- Apr 21, 2015
- wilmington nc
this has been a continuing saga for me. i have a hole that needs to be tapped M6x1. the chart calls for a 10 mm hole. i bought OSG taps. I drilled the hole. The steel is the only unknown because I bought it at the local salvage yard. No markings but soft enough to file and it turned quite nicely. I used carbide insert tooling. the fist hole i did the tap, a spiral threaded one,
( the kind that shoots the chips out the back end of the tap), sailed in on my slowest speed on my sb 9a with the tap held in the tail stock in a Jacobs chuck with the lathe in back gear. Nice and slow as I said. Plenty of tapping oil, tap magic is the brand. Then suddenly it snapped. that's number one, and I cant get it out because it snapped deep in the hole. the second time different hole it didn't make it even a half inch before it snapped off. What in the hell am I doing wrong?
