Idler Gear Removal
j c
Dec 20, 2013
Queens
Hi,
Does anyone know how to remove the two idler gears on the back of a SB 9 1940. I took of the back nut but still wont budge.
I am putting on a thrust bearing for the spindle.
Thanks a lot,
J C
You mean the two little gears on the reverse tumbler? You don't pull those, you remove the whole reverse tumbler from the headstock.
allan
Hi,
Thanks for the reply. How do I remove the reverse tumbler? I got the square bolt and the one gear off, but nothing more.
J C
I figured it out. Sorry for the basic questions. I had to remove the large flange on the bottom gears for the tumbler to slide out.
Got my thrust bearing on the back of the spindle now and it makes a huge difference in performance.
