Cleaning up the motor on this 9A- get the crud off the nameplate and it's KC Electric Co- and the model says "SB"... would this really be the original motor some 65 years old?
Runs smooth, rewired the lead into the junction box (there was no provision for an external ground so I used the screw for the cover plate to hold a crimp connector).
Came with a wall switch (literally) that had replaced whatever was originally on top of the gear guard- but the only drum switches I see are FWD-REV-OFF types, and I just need a simple on/off. What was originally used?
Maybe apples and oranges...but I'm not an electrician...
But I use an inexpensive speed controller on my gunstock duplicator routers- I don't suppose something as simple as this could be used to control this motor speed (1/2 hp, only 7.3 amps at 110v) outside of the belt speeds? Or is this not anything close to the same application given the torque involved?
