Ronniet
- Feb 21, 2011
- Amarillo Texas
after reading all the posts about upgrading the dials on the 9 an 10s I decided I would do mine as it needed a new screw and nut anyway.
My 11 is different, see pictures,
The new Acme is installed and drying and it will be pinned in front of the gear in the 1.125 smooth stub in front.
There is no large shaft behind the gear , what you see is what it is.
The shaft measures .625 o.d. with a lighter cut in between at .600 and everything behind the gear is 5" long O.A.
The small dial bushing as shown in the picture has one thin brass washer that buts up behind the gear,, the bushing goes a ways into the slide before threading.
Even though threads are at the front of the slide.
My intension is to use most of the .625 o.d. shaft, turn the bushing down at where the hex nut is to a manageable size and make a 1.750 size short bushing to "sweat" on to this original bushing, then turn down the exposed .625 shaft to the .375 size and continue on from there with the 200 type dial and short bushing/bearing.
Anything wrong with that?
I need opinions , I only have the one gear shaft.
Ron
Ron
