pwcosol
- Aug 5, 2004
- Palmdale, Ca.
Several Forum members were very helpful when I was trying to wire up a fwd/rev switch to my lathe motor. Everything worked out well, but now I have a new problem. After selling my old Atlas I set up the same motor to work on my new lathe. All I had to do is shorten the wiring & shielding from the switch to the motor, & reverse two wires (per data plate) to make the motor start in reverse, since the motor pulley was oriented opposite the way it ran originally.
Everything worked fine until I put the belt on the motor pulley. It turns out if there is any load on the motor pulley at all, the motor hums & it will not spin up. Give the belt a good tug; either forward or reverse, and the motor takes off. It seems the capacitor start is not kicking in. I thought I may have inadvertently reversed some wires, but nothing seems to change the equation. I replaced the motor-start capacitor, but that didn't help either. I was told there is a relay or switch inside the motor. If anyone has experienced a similar difficulty or has any thoughts on what I can do to get this thing working right again, I would appreciate your input. It is a very clean, almost new motor, and ideal for my purposes, so would hate to dump it if it is a minor problem that can be fixed. Thanks!
