Longer bolt on 13" rear leg casting?
John Strange
Aug 1, 2017
On the 13” CL145 model lathe was it standard that one of the 4 rear leg bolts (which pass through half the leg and chip pan then into rear leg casting) be slightly longer than the other 3?
If so, where in the Front/Back - Left/Right configuration would the longer one go?
If not, then I suppose I should check the length of the 4 bolts that secure the half leg to the bed for one that is shorter than the rest in case there was a mix up at some point.
