yoshimitsuspeed
- Jan 25, 2014
- CO USA
Hey guys, I picked up a heavy 10 a couple weeks ago. I finally got it positioned and setup with a VFD. I got it running today and got to do a little work on it. The thing was very loose at first but after tightening up the ways it's not bad.
I am looking for manuals, maintnence and service guides as well as any other info I can find. I read through the links in the stickes but didn't find much specifically for the heavy 10. I did find a yahoo groups that's supposed to have files but I am waiting to be accepted to the group.
I was thinking about getting this kit in the near future.
Rebuild Book Kit for South Bend Lathe 10L "Heavy 10" | eBay
Is that a good manual?
Is there anything better?
Since I am recovering from buying the mill and a few big projects is there anything free to get me by for the time?
I do also have a few specific questions right now.
One issue I noticed is the chuck and shaft has about .5mm of axial play. I assme this is not normal? How do I fix it?
It doesn't feel like there is any radial play.
The VFD won't start the motor on it's own. I was thinking it might be something wrong with the motor or the settings but I am wondering if it's related to the chuck being hard to turn. It definitely has a bit more resistance than other lathes I have used and almost seems to be a little stikier when it's stopped. If I want to turn it by hand it can be a bit challenging but once it 'cracks loose' it spins a bit easier. Same when I press go on the VFD. I can give it a light tap in the right direction and it will take right off.
I have made sure the oil is topped off on all the reservoirs I have found but that is about it for that.
The last thing is that the ways are a bit worn in the common travel spots. When it's tight there it's pretty hard to move in the less traveled areas. Are there any tricks to evening it out?
I do ceramic coatings and have some very hard, tough and slick coatings available. I am almost thinking of coating the more worn areas to build it up a bit.
Definitely open to other suggestions.
