Domodude17
- Aug 14, 2017
I bought a SB9A and cleaned it up a while ago before winter and it's low temperatures set in. I followed the restoration guide book you can get on Ebay. In it, it said to use grease between the back gear and the spindle-the two shafts would be spinning at different speeds when the back gear is being used. I put some grease in there and didn't think anything of it, until I recall seeing some discussion on this a few weeks ago where people were saying that they used grease, and had the back gear seize in the spindle.
Should I take this apart to remove the grease and replace it with oil, or is it likely fine?
