bradjacob
Titanium
- Nov 18, 2008
- Easton, PA
Hey guys -
I had been given a machinist vise that was missing it's conical washer and clamping-yoke. Made both on the South Bend 13.
Turned the radius by moving the compound in various angles to remove the most material. Then, I filed the final contour. Drilled the though hole and parted it off.
Next, was the yoke. Turned to diameter, then drilled/tapped for the clamping screw. To give it a stylish touch, I mounted it in the spindxer and milled two flats 180* apart. To complete it, I turned a radius and filed to final contour.
Here is a video that shows the process. Hope you like it.
http://youtu.be/DAt8Zf--PDM?list=UUuFJaKZoZDKB-aC7o8Zk-dg
