metric SB question(s)
Results 1 to 6 of 6
    Oct 2005
    Sacramento, CA
    69
    Default metric SB question(s)
    Hello all,
    I recently acquired this 10" (25.4cm?) lathe, but I can't seem to find any information about it. Is this a full metric SB lathe? I attached a picture of the front and back of the serial card. I also included pics of the quick change box compared to one on a 10R. The metric box is backwards to the standard box! And Spanish is all over this thing! What part of the serial number, catalog number, etc. represents metric? Are the compound and cross slide metric pitch as well? Any information would be appreciated.
    Regards,
    Jeremy
    [email protected]
    Aug 2007
    5,201
    1127
    1008
    I'm not sure from your message which is yours or which is not.
    2nd pic is an inch lathe, that's why it says "inch threads".
    The 3rd pic is that of a metric lathe, that's why it says "Pitches in mm".
    This is going off the plates, to really know you would need to count the teeth on the gears. Should be a 127/52 gear if it's metric, AFAIK.
    Jul 2008
    South Bend, In
    2,402
    119
    192
    That is a metric gearbox. If the whole lathe was built as a metric machine, it would have metric screws (CF, Compound, and leadscrew)dials to match.
    Tailstock would have Metric grads on the spindle.
    Ted
    Mar 2016
    New Jersey
    912
    16
    178
    Interesting gearbox. Looks like they took the standard one and basically reversed the lever setup.
    Dec 2012
    St. Louis, MO
    252
    52
    Quote Originally Posted by traditional-tools View Post
    If it is an all metric lathe from the factory, it will have a metric lead screw and won't have a transposing gear; also, the thread dial will look weird: with tick marks for metric pitches, not the 1,2,3,4 and half-marks normally seen.
    If it is metric, you will need a transposing gear to do inch threading. Kind of the same issues as doing metric on an inch lathe only in reverse.
    Here is a thread dial from a SB13 metric for comparison:
    Jul 2010
    Virginia, USA
    3,166
    76
    508
    Quote Originally Posted by gadget73 View Post
    Yes, given how the metric thread series progresses, (it is a reciprocal vs imperial threads) the cone gears have to come before the compound gears. The most interesting lathe for that is the Cinci tray top- they have an auxiliary gear and shaft to insert into their gearbox, which sends power through the box backwards, and takes output from the other side. This removes the need for so many stud gears when turning metric threads.
    allan
