Erich
Hot Rolled
- Apr 4, 2017
- Poway, CA (from Location field)
I have a 1943 toolroom Heavy 10.
It is equipped with the large end cover with a plate describing which gears are required to cut which metric gears.
I have no extra loose gears.
Also the banjo on my lathe is just a straight piece. I have seen pictures of other banjos that are Y shaped. But those pics were from a later lathe with the double tumbler gear box.
So What am I missing or what is the wrong part for my lathe.
I have a copy of the lathe index card from SB it says the "Transp. ATT" should be code 534.
Think this means the lathe is supposed to be equipped with the metric gears.
Lathe was also equipped with the coolant pump. Except for a drain screen in the chip pan and some seals between the headstock and bed, there is nothing left of that either.
