Most medium sized lathes use 16 D.P. 14-1/2 P.A. change gears.
Boston Gear makes 16 D.P. 14-1/2 P.A. change gears in every tooth count from very low to at least 128, including the all important 127 and 100.
(You may have to bush the bore for your particular machine).
For smaller machines, or for special applications, you may want to use 20 D.P. or even 32 D.P.
The "end gear" unit of the Monarch 10EE, for example, is totally enclosed in an oil bath, which imposes severe size constraints. A 127 tooth metric transposer of 32 D.P can be accommodated, but not one of 16 D.P, which is otherwise the standard pitch of all the gears in the "end gear" unit. Therefore, a compound gear of 127 T, 32 D.P and 60 T, 16 D.P. is part of the 10EE's metric transposer. "End gears" of 45, 50, ..., 75, 80 T, 32 D.P., complete the 10EE's metric threading kit.
