Micrometer Stop with Dial Indicator 16" lathe
Results 1 to 17 of 17
    Mar 2010
    Nashville, IL USA
    347
    20
    Default Micrometer Stop with Dial Indicator 16" lathe
    The other day I took my micrometer stop apart for cleaning and to take some measurements because I was going to make a bracket for a dial indicator like I've seen others have. After taking it apart I decided I could just make a new spindle for it that would double as a dial indicator holder. Here are some pictures of what it looks like.
    http://i245.photobucket.com/albums/g...p/DSCF0839.jpg
    http://i245.photobucket.com/albums/g...p/DSCF0840.jpg
    I made a brass plug with a oring on it to put in the hole when i'm not using a indicator.
    http://i245.photobucket.com/albums/g...p/DSCF0844.jpg
    Here's one with a 3" travel indicator.
    http://i245.photobucket.com/albums/g...p/DSCF0845.jpg
    Apr 2009
    Sticks, Indiana
    772
    62
    50
    That’s a lot classier than my 16” set up! What travel does that indicator have? Thanks for sharing, that’s a fine idea you had.
    Feb 2009
    New Jersey, USA
    200
    A great idea beautifully done!
    Mar 2010
    Nashville, IL USA
    347
    20
    The indicator in the first picture is just a 1" travel with rod extensions to get it all the way thru the new spindle. I got the extensions from McMaster Carr McMaster-Carr
    The indicator in the last picture has 3" of travel.
    Feb 2009
    New Jersey, USA
    200
    How do you make the end of the shaft and the nut so they become a collet and squeeze the micrometer shaft when tightened? Are the threads tapered somehow? How big is the bore in the holder relative to the diameter of the shaft on the micrometer?
    Mar 2010
    Nashville, IL USA
    347
    20
    The end of the threaded area has a 45 deg. chamfer on it and I cut a mating taper in the nut. The bore that holds the dial indicator is a close fit with shank on the indicator and the nut squezes the bore tight. I don't remember what size the hole is that the moving stem comes thru but I have a sketch out in the shop, tomorrow I'll try to find and post it.
    Mar 2010
    Nashville, IL USA
    347
    20
    Here are the sketches I made when I was making the stop. Any dimensions I left off were copied from the original spindle.
    [IMG][/IMG]
    Feb 2009
    New Jersey, USA
    200
    Thanks very much for posting the details -- it's much appreciated.
    -Chris
    Jan 2009
    belleville,il
    184
    67
    18
    Added to my project list. It looks like a must make item to me.
    Thanks Clay
    Feb 2007
    Lewistown, MT
    140
    Very nice!
  11. #11
    Mar 2005
    Washington
    384
    21
    11
    OldMachinist,
    I've read this thread and looked at your pictures over and over. Great Idea, Nicely executed! I am inspired! Thank you for sharing.
    -daleroe
  12. #12
    Oct 2007
    new carlisle, ohio
    80
    Very nice indeed!
    New Carlisle John
  13. #13
    Feb 2004
    peekskill, NY
    23,686
    3879
    If one does not have the original SB micrometer stop available, another approach:
    Broken apart it looks like this:
  14. #14
    Mar 2010
    Nashville, IL USA
    347
    20
    Thanks for the compliments folks I'm glad you like it.
    I wanted add something since some people are thinking of making one. The only tricky part about making the spindle is cutting the 6 slots on the threaded end without distorting the part. I cut them with a die grinder and abrasive cut-off wheel mounted in a lathe milling attachment. This left nearly no burr and didn't distort the part.
    I put the part in a hexagon collet block and put it in the 3 jaw chuck. I had the back gears and bull gear engaged to lock the lathe spindle. I advanced the cut-off wheel in with the apron by hand to depth. Backed off the apron, loosened the chuck and indexed the collet block one jaw and repeated 2 times.
    Click to enlarge
  15. #15
    Aug 2009
    Dumbarton, UK
    546
    Just out of interest, and because I did some work with a slitting saw for the first time earlier this week, the collet looks to be engaged to the block with a drawbar so it can be moved around as you want? In which case it could be mounted in the vice on the milling slide using 2 flats to index each time?
    If so another way to achieve a similar goal would be to use a slitting saw on an arbour held in a collet (or the chuck if it's true enough). I don't think I had much of a burr with this approach - mind you I had to drill and tap perpendicular to my slot so I filled it with swarf anyway.
  16. #16
    Mar 2010
    Nashville, IL USA
    347
    20
    I was going to use a slitting saw in the mill but didn't have one thin enough on hand(plus I couldn't find my arbor) so I decided just to use the cut off wheel.
  17. #17
    Aug 2009
    Dumbarton, UK
    546
    Cool, just checking. There are more than one way to do most things, I have a slitting saw (now) but no die grinder
    Here is my slitting saw in action on my take up nut:
    Jim
