Cheesebeast
- Jan 4, 2017
Hello All,
I am a newbie who could use an experienced eye to look over my evil plan to get a South Bend 10K up and running.
It is a South Bend 10K, Catalog# CL 670 Z, Serial number 35702K. I think that means it was made about 1978/79. The lathe is missing the motor, motor pulley, belts, and various mounting bolts.
My plan is to source a new motor- 3/4 HP, TEFC, 1800 RPM.
A VFD- Teco Westinghouse (AC Drive, 1hp, 115V, Single Phase, Medium Duty)
A serpentine belt from an automobile (6 rib, 27/32" wide, 47.5") that will be glued (or sewn together with fishing line)
A V belt, not sure what type or size.
And a replacement motor pulley.
If I am using a VFD do I have to source an original motor pulley (5/8", P/N PT2131K1, 3.956" and 2.237")? Can I just go with a single pulley size (guessing- 2.5")?
The machine is loaded with a thick layer of machine shop grime, but it appears to my untrained and ignorant eye to be in good shape. It isn't rusty, just grimy.
I guess a full felt replacement is in order once I get through the grime layer.
Thanks for any and all advice you can give to help me execute my evil plan!
